SpotlightInserting a straight truss
Mode
Tool
Workspace: Tool set
Modes for Creating single lines
Straight Truss
Design Suite: Detailing
Spotlight: Rigging
Insert and configure straight trusses with the Straight Truss tool. Straight trusses function as rigging objects, so lighting devices and other loads can attach directly to the truss. Straight trusses support full 3D rotation, and they can be used to create schematic views.
Straight truss parameters are illustrated by the following diagram.
To add a straight truss to the light plot:
Click the tool.
Click to place the object in the drawing, and click again to set the length and rotation.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Trusses are 2D/3D hybrid objects. Complex trusses can increase the time required to render the model in 3D.
Parameter
Description
Roll Angle
Rotates the truss on its X axis; the truss rotates around its insertion point
Hanging Angle
Rotates the truss on its Y axis; the truss rotates around its insertion point.
When this angle is adjusted, the truss may appear shorter in Top/Plan view, and attached loads may appear to overlap.
Rotation
Rotates the truss on its Z axis; the truss rotates around its insertion point
Position Name
Enter a name for identification and reporting purposes. When the truss is used as a hanging position, this name automatically populates the Position field of any attached load objects.
Index
Specifies a unique identifier for the truss, which is combined with the Name for identification and reporting purposes
Length
Specifies the length of the truss in drawing units
Cross Section
Displays the associated cross section information for Braceworks structures
Truss Cross Section
Displays the cross section unique ID number, when a cross section file has been associated with the truss as described in Specifying cross section data.
Cross section information is required for valid calculations; if there is no identified cross section, calculations will not be complete.
Profile
Select the truss profile from the list
Connection
Select the type of connection from the list
Connection Interval
Indicates the distance for dividing the truss into component sections
Folding
Indicates a folding truss
Pre Rigged
Select whether to include a light bar
Height/Width
Shows height and width values for the truss
Chord Profile
Select round or square chord tubing
Chord Width
Shows the diameter of round chords or the width of square chords
Ladder Bar Spacing
Specifies the interval of the ladder bars
Ladder Bar Profile
Select round or square ladder bar tubing
Top/Side Ladder Bar Diameter
Indicates the diameter of the top and side ladder bar tubing; enter 0 to draw no ladder bar
Lacing Profile
Select round or square lacing tubing
Top/Side Lacing Diameter
Indicates the diameter of the top and side lacing tubing. Enter 0 (zero) to draw no lacing.
Distributed Weight
Specifies the weight of the truss along the length of the truss
Show 3D Detail
Renders the truss with greater 3D detail
Show Direction
Places a directional indicator on the truss
Highlight
Displays odd sized truss divisions in red
Message
Provides information about the truss placement and indicates successful placement
Select Truss System
Selects the current truss and any other connected structural elements in the system
Convert to Hanging Position
Selects the entire system, including the truss and any connected rigging objects, for conversion to one or more hanging positions. Any attached loads are associated with the created hanging position(s); see Creating a hanging position object.
A connection interval shorter than the defined interval length is displayed in red when Highlight is selected.
Concept: Rigging objects
Inserting a curved truss
Truss configuration requirements
Replacing stage decks and trusses with symbols
Inserting hanging positions
Concept: Hanging positions
Concept: Braceworks structural analysis
